damn... encoded a bunch of tv episodes to VCD with tmpgenc... using powerdvd, everything looked fine... then i watch some on the tv and the mouths don't match words... i think this has to do with the audio being encoded in divx also... in the past, when the audio is compressed with xvid or mp3 or divx, i usually decompress the entire audio in virtualdub b4 encoding in tmpgenc...(that usually works), but since i have a ton of .avi files, that would take up too much drive space...
do you think frameserving from vdub to tmpgenc would solve the problem? is there some other way to avoid the audio fallin out of synch?
so i've read these forums, and one thing i was gonna try is usse vdub to fix the 2sec delay... BUT, the problem doesn't show up in vdub??!! it plays fine... it's only outta synch when the file becomes a .mpg i tried using vdub to save a .wav then encode the video and audio sepearately, but still outta synch.... although the .avi and .wav have the same time length... why can an .avi play normally, but the encoder doesn't encode it normally? (the audio is .mp3 by the way)
Playing and encoding isn't the same thing. A player can overlook difficulties in decoding the source, just skip ahead, an encoder can't do that. Is the MP3 audio CBR or VBR?
Is it out of sync by the same amount all the way, or does it change at some point, or does it slowly drift out of sync?
/Mats -
CBR, it is out at first, then slowly in, then out... or maybe it's out all the way...
Sounds like bad/undecodable frames in the AVI - did you check it with VirtualDub MP3 Freeze?
Do you encode to the same frame rate as the source?
/Mats
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 11:50 -
4.9GB Vid + 2.1GB Aud = 8.6GB?!?!?
By BurkettC in forum Authoring (Blu-ray)Replies: 6Last Post: 10th Jul 2009, 19:43 -
cheap m.b, cpu, case package withonboard vid&aud&lan - @zipzoomfly
By minidv2dvd in forum ComputerReplies: 6Last Post: 25th Sep 2008, 04:07 -
Newber: easiest solution 2 convert dvd (aud/vid .ts) from HD to NAS in MPG
By gizfs in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2008, 19:27 -
DIVX DVD Player Audio Synch problem
By wulf109 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Mar 2008, 09:14
