Is there any easy program that burns multiple svcds on one dvd. i´ve bought a couple of dvds when i was abroad and there could be up to 4 different movies on one dvd. What program can you make these kind of dvds with?
If your source is SVCD:
svcd2dvd
If your source is DVD:
Don't convert to svcd. Convert to dvd with low resolution instead. Use for example dvd rebuilder. Select Half D1, convert each, and then join them with tmpgenc dvd author or dvdremake to keep the menus and crap.
If your source is something else:
Don't convert to svcd. Convert to dvd with low bitrate and low video resolution and you can fit several hoours/dvd. -
Assuming you have SVCD mpegs, and you want more than one on a DVDR, then DVDLab will directly author SVCD mpeg's to DVDR.
If you have some other source, then it's best to follow Baldrick's advice.Cheers, Jim
My DVDLab Guides
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 16:50 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 19:44 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29
