hi major i read a post about how to convert from ogm to avi... and you said use divx (libavc) quick preset and audio preset = 1.
i use ffmpegx 0.9s and there's no quick preset such as divx (libavc)... so thw question is which preset should i use to convert from ogm to avi.
by the way i can watch this ogm file in vlc but when drag and drop the file in ffmpeg it says unrecognize?
any help?
thanxs
dj_yerba says: legalize it!
VIVA CHILE MIERDA!
Hi, I'mk not major but I think I can help.
Basically DivX=MPEG4 and libavc=FFmpeg, so select mpeg4 (ffmpeg).
Where is the Major... ??
By moon47usaco in forum ffmpegX general discussionReplies: 2Last Post: 12th Aug 2010, 13:22 -
Have major problems with dvdauthorgui
By blue-eyed in forum Authoring (DVD)Replies: 1Last Post: 26th Apr 2008, 00:05 -
Need Major help from an expert!
By jbartosh in forum MediaReplies: 38Last Post: 23rd Oct 2007, 13:45 -
Major Audio Distostorion
By Macaw in forum DVD RippingReplies: 1Last Post: 23rd Sep 2007, 06:59 -
major problem
By Antitrust19 in forum ComputerReplies: 6Last Post: 28th May 2007, 09:30
