  1. im having problems copying layer cake and resident evil 2, however some people are saying that u can do it with decrypter and shrink what settings do you set decrypter to?????????please help
  2. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    Aug 2004
    fritzi93
    Member
    Posted: Mar 13, 2005 12:38
    Pardon me for resurrecting this one. Just to confirm it ain't tough.
    Ripped with DVDDecrypter, ISO Mode. Pertinent settings: Aggressive Structure Protection Removal, Detect Mastering Errors, RCE Region 1, Remove PUOs, everything else at defaults, including CSS Cracking ( I/O Key Exchange -> Brute Force).
    Straight reauthor in DVDShrink caused a memory error. Do over. Went to start/end frames, jumped to chapter two and used the back button until I stopped it at two seconds, zero frames. That became the start point, left end frame alone. Hit Backup, no problems. DVD plays correctly all the way through.
  4. Just a couple notes:
    Those settings worked with "The Forgotten". Do a search on your specific movies, they've been discussed, I'm sure. Also, many people recommend File Mode, I tried ISO Mode just to see if it would work. For File Mode it might be a good idea to tick Multi-Angle Processing and Retain Angle One. And specify RCE Region 2, rather than Region 1.
    Good luck.
    Pull! Bang! Darn!
    Aug 2003
    north east england
    just download the latest version of anydvd and you will be able to copy it with any of the programmes
