Hi, I have DVDAuthorGUI and i haven't been able to use it because when i click on it to open a message comes up that say's "Component 'comdlg32.ocx' or one of its dependencies not corectly registered: a file is missing or invalid" How can i fix this so i can use dvdauthorgui?
Download the latest dvdauthorgui 0.998b and be sure when installing, to select a "FULL" install. This will install the activeX runtime files for you.
just try 2 import the file if its a windows file from win setup otherwise from a friend whose having dvdauthor gui
Hey, Thanks for the advice. It works now, Thank You. I thought i had the full installation but i guess i didn't.
Rusty
video file and subtitles file are out of sync because of missing intro
By bmaya in forum SubtitleReplies: 3Last Post: 13th May 2010, 12:26 -
BD_Rebuilder Bug or File missing
By Raul124 in forum Blu-ray RippingReplies: 1Last Post: 18th Nov 2009, 03:01 -
Audio missing in VOB file
By marknyc5 in forum DVD RippingReplies: 3Last Post: 20th Jul 2008, 20:48 -
Missing a .VOB file?
By Ego Tripper in forum Newbie / General discussionsReplies: 5Last Post: 2nd Feb 2008, 17:02 -
Breaking down a VOB file into its component parts
By djdust in forum Newbie / General discussionsReplies: 3Last Post: 5th Sep 2007, 22:06
