i am using win dvd rec, winfast pvr , fly tv 2000 & nero vision express to capture tv & have experienced frame dropping with at least some of these applications.
is there anything i need to check to stop this?
i am capping to a seperate HD which has been defragged & using a seperate graphics card GeForce.
i am rec to mpeg2 to then burn to dvd
i have a P4 1.8
768 M ram
at the most i may have anti virus running but do try & remember to disable that before capping, otherwise def no applications
didnt think about spyware running though?
certainly dont browse whilst capping
also cap to a seperate HD -
Search for a program called Enditall. I don't know if it still free or not. It will allow you to turn off programs and processes. It would help if you filled in you computer specs.
thanks for that
my pc specs are
P4 1.8G
768 M Ram
Geforce 4 graphics card
on board sound card.
capping to seperate 20G HD -
See the sticky about dropping frames, that's why its a sticky.
Put computer specs in your profile for future use.
Try capping with no audio as a test, onboard sound often an issue.
Blackmagic Intensity Pro dropping frames when recording with MJPEG.
By leslij55 in forum Capturing and VCRReplies: 2Last Post: 23rd Nov 2012, 23:02 -
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 12:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
WinDV dropping frames
By 2Bdecided in forum Capturing and VCRReplies: 3Last Post: 17th Oct 2009, 04:23 -
HDVSplit dropping frames
By Boadicea7 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2009, 09:47
