I have Plextor PX 708A. I burn disks with Nero 6. But I have problems, trying to burn TDK or especially Maxell DVD-R media. The writing is normaly ended succesfully but verification failed, data is impossible to read. The disc are on the "under" side colorful - there are some parts darker, some lighter and than again some darker... What can be the problem - writer, program or media? Thanks for all sugestions or answers!
Results 1 to 21 of 21
sounds like defective media. use DVDINFO PRO to get the media codes from those TDK & MAXELL. I use TDK media code TTG01 & MAXELL media codes TYG01 & MXL RG02 on my PLEXTOR 708 with no problems. Some MAXELL DVD-R media is RITEK made in taiwan. TDK DVD-R media could also be made in taiwan CMC which is crappy for the PLEXTOR 708A drive. Use the RECOMMENDED BRANDS OF DVD MEDIA that PLEXTOR supports. Media code, Media code is important not just the brand name. Get the MADE IN JAPAN spindles which can be read on the spindles of the MAXELL & TDK.
Thank's. The suplier tell me some minutes ago, that he recomended me to buy "+" media, because "-" isn's as good as "+" for big files (my files are biger than 4 Gb - one file). I try and report.
Its just like budz says, check them TDK and Maxells to see what they ACTUALLY are. They are both probably the cheap Taiwanese versions, not Maxell or TDK true.
What the supplier told you is a load of codswollop. Nothing to do with if its "+" or "-"
DON'T waste your money on his suggestion. The guys here know better than him. Trust me. -
it's not "minus" it's "dash"
Originally Posted by stiltman
Originally Posted by gumpec
https://www.videohelp.com/forum/viewtopic.php?t=260010
You could always try a quick and simple ISO read and write with Decrypter and see if the media shows the same after writing.
With my 708A I always got one dark ring using Maxell yellow tops (either TY or MXL code). With TY 4x from Rima I never got any discoloration. Get the code to know what the exact media is as budz suggested.
NL -
Nothing logical about being wrong.
it's the media and your plex doesn't like it
what's the diference between dash and minus....????/ -
But think of Volkswagen and other foreign brands if they are pronounced here the way they are pronounced in their country of origin. And who cares? It is more convenient and easily distinguished. Believe me, in every store I went to, those guys easily understand when I ask them "where are your DVD minus Rs? Not one said "what are you talking about?'
Now, how many people specially the newbies call it dash? I do not speak English fluently but I know "dash" has a lot other meaning aside from that little horizontal line. So "hyphen" is more appropriate if you will ask me. -
purely a FYI thing
its a dash but you can call it whatever you want for what ever reason you want
Dash commonly known as minus, thats fine, whatever -
You can try to justify it all you want. It's still simply wrong. And it's not a hyphen either. It's a dash. A dash is a slightly longer line.
Naming the product DVD+R was simply a marketing ploy. DVD+R was made in the first place, simply to circumvent paying royalties etc.
The +R just named so, to make their product look superior.
Both media's can be good, and horrible. Both media's are compatible on almost all DVD Players on the market today.
Just go with quality + or -, and you should be fine.:star: :star: :star: :star:
Archived DVD Scans
Nero V ImgTools V Decrypter
:star: :star: :star: :star: -
I rest my case. Bye!
Originally Posted by richdvd
Internet for Beginners
Originally Posted by Internet for Beginners
Originally Posted by TechWeb -
DEE-VEE-DEE-ARRRRR (DVD-R)
DEE-VEE-DEE-PLUS-ARRRR (DVD+R)
SEE-DEE-ARRRRR (CD-R)Want my help? Ask here! (not via PM!)
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
