I have an avi which has no audio when I play in Windows Media Player. The audio does work in Media Player Classic. When I load the avi in TMPGenc it says invalid audio source. I tried decompressing the audio using avi2vcd and then changing back to ac3 with ffmpeg. By doing this TMPGenc accepted it but the finished DVD had no audio.
Thank you in advance for your help.
When you say "decompress and change the audio back to ac3" do you mean the original file has ac3 audio?
If the file uses ac3, my guess is you do not have an AC3 audio decoder installed. Media Player Classic has a built in AC3 support, that is why you hear audio with MPC.
Install AC3 Filter to add AC3 support.
I just have one question, why are you using WMP when you can use Media Player Classic?
*shivers at the thought of using WMP.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
If your avi has AC3 audio then to make a DVD you need only to convert the video. Extract the AC3 audio from the avi and author it with the converted M2V video to make your DVD. Baldrick's guide.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks guys! Followed your advice Zippy and it worked. Thanks for your time and help.
AVI with AAC audio to AVI with MP3 audio
By Neroon in forum Video ConversionReplies: 6Last Post: 30th Jun 2010, 09:15 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
Dual audio AVI to singl audio AVI.
By Benhermies in forum EditingReplies: 8Last Post: 20th Aug 2008, 21:44 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22
