I converted an .rm file to uncompressed .avi using the Tirna software. But the framrate of the .avi was too low, 2fps, therefore i used virtualdub:
Video-->Framerate-->change so video and audio durations match
But this hasnt worked neither. Should choose Direct Stream Copy under the video menu and save it first then compress the corrected file or can i just do the two things at the same time??I need a good method to make the video and audio match
And is there any other handy software out there that does a better job converting .rm to .avi without producing a HUGE filesize? I cant convert .rm videos that are over 20 minutes or so because they go over the 4GB per file limit.
Thank you guys
Try converting .rm to divx first with EO VIDEO... I posted it here and a patch:
http://groups.yahoo.com/group/buzzinhornetz2001_22/files/
DV-> AVI conversion
By bodomalo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 28th Dec 2010, 22:06 -
avi conversion
By joecass in forum Newbie / General discussionsReplies: 11Last Post: 11th Aug 2010, 15:11 -
TP to AVI conversion
By nic3 in forum Video ConversionReplies: 0Last Post: 20th Nov 2009, 18:04 -
AVI to .Mov conversion
By HD_Shooter in forum MacReplies: 10Last Post: 18th May 2007, 08:45 -
Avi conversion probs
By hitmanhill in forum Authoring (DVD)Replies: 15Last Post: 12th May 2007, 09:21
