What is the media ID on these?
They are on sale at Office Depot this week.
Any comments from users welcome.
Results 1 to 13 of 13
the last Philips 1-8x dvd-r's I bought at Office Depot were CMC and were a disaster. My admittedly persnickety NEC1300A couldn't even recognize them as DVD's. I don't remember the code, but my free advice is don't bother. Office Depot refunded my money twice.
If you're near a Best Buy (USA), they have Fuji +r's and -r's on sale for $20.00/50 this week. SOME of these are going to be made in Japan TY's which most people on this forum say are good. Some will be made in Taiwan. Read the labels carefully. -
My NEC 1300 burns CMC AE1 discs perfectly (8x -R), you may have had an old FW that didn't recognize the media code.
I'm still at 1.05. Haven't found the nerve/time to upgrade firmware. So much for free advice.
It doesn't require nerve or time, it takes 2 minutes and can easily be done in Windows. Changing the FW takes 20 seconds and a reboot, that's it. If you want any suggestion on what firmware to use let me know (it'll improve your burner so I'd suggest updating it).
See this thread over on the Anandtech forums:
http://forums.anandtech.com/messageview.aspx?catid=40&threadid=1542850&enterthread=y
You can pick up a Benq 1620 burner for less than $50 delivered, then donate your Nec 1300 to GoodWill. -
Yeah, I'll even pay for the shipping to me :Pthen donate your Nec 1300 to GoodWill.
I have an NEC-1300A also. I just purchased some Memorex 8X DVD-R's last night at Staples because they were on sale for $20 for 50. When I got home and tried to use one, Nero Express 5.5 (what came with the burner) wouldn't let me select over a 2X burn speed. Then when I hit the BURN button as soon as it started it stopped and said "Illegal Media". I've had the drive since it very first came out, so thats about 2 yrs I guess. I've never updated the firmware. I dont know what media code the discs are, I dont even know where to look for that code. I just learned about it from reading this post. Any help here would be appreciated. Should I just return the discs and buy a different brand? Should I try updating the firmware? Its almost impossible to find 4X discs in stores now. Where on the packaging is the media code listed? Thanks.
Media code is not listed on the packaging, you have to look it up with a program such as DVDInfo, by putting the disc in your drive.
Update your firmware with the 1.0C version on this site:
http://www.herrie.org/
Phillips DVD and codec problem
By lyon in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Apr 2010, 01:55 -
Phillips DVP5982 vs Phillips DVP5992?
By jarko in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th Jul 2008, 13:41 -
Are Phillips brand DVD-R's any good?
By Nexxous in forum MediaReplies: 9Last Post: 31st Dec 2007, 12:11 -
Will a Phillips DVDR3475/37 play DVD +R DL discs?
By c5vetman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Nov 2007, 12:47 -
Phillips DVD 8801 and Verbatim +R DL problems
By c5vetman in forum DVD & Blu-ray WritersReplies: 6Last Post: 30th Nov 2007, 11:39
