  1. i have had my ps2 for a few years. it has worked fine until about a week ago. it stopped playing some of the games. i just bought two new games. and they dont work it just says disc error. i would if someone could help me out. thank you
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Frank, most likely your either going to have to replace the drive mech or get a new PS2.
    You could always try a cleaning disk but we all know how often that works.
  3. Member pyrate83's Avatar
    Alive on XBOX LIVE!!!!!!!
    Flaystus is right. Sounds like your drive may have slipped out of alignment. Replacement of the drive would be a good option.
    Jul 2002
    Up in yo' bitch.
    Maybe a laser calibration problem. If search in Google for the problem, there will be several sites listed with instructions how to fix this.
  5. thanx alot, i might take a stabb at opening her up and fixing the lazer. thank you again
  6. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    my buddy recently did the laser alignment fix and said it worked like a charm and only took him about half an hour
    luckily, I have had no problems with my PS2
    good luck!
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
