Hi,
I was reading through the online guides on how to use VCDeasy. It tells you to load your files in the order that you need to use them but doesn't tell how to make the physical menu file. I have been able to get from WinDV, through Virtualdub, past TMPEng and finally into VCDeasy succesfully. Yeahhhh! But I am stuck on the menu point. TMPEng does not let me open a bmp or jpeg file to create an mpeg file and VCDeasy seems to demand an MPEG file.
BTW, I have freeware versions of all software
Hi!
You have to convert your jpg menufile to a mpg.
Select "Pictures Encoder" in the left toolbar of VCDEasy
Click the "File(s)" button and browse to your menu picture file.
After the conversion, import the mpg menu file in VCDEasy.
This is for VCDEasy 2.1.1, I don't remember where the selection where in older versions, but look around in the program to find where you can create mpg stills from pictures.
// Znooky -
Thanks! I just upgraded to 2.1...it is much easier to work with and will give me mpg2 as well..
Jump to menu is making me mad
By Allfreeware in forum Authoring (DVD)Replies: 0Last Post: 15th Dec 2011, 12:05 -
Help with making menu's!!!!
By BananaKing in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2011, 07:55 -
I need a DVR that can record without making a menu page
By khicks in forum DVD & Blu-ray RecordersReplies: 14Last Post: 23rd Sep 2010, 16:41 -
Making a Dual Layer disk with menu
By Regor21 in forum Authoring (DVD)Replies: 7Last Post: 8th Apr 2010, 08:34 -
particular Menu-making feature
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 15th Feb 2008, 15:38
