I am converting my WAV file from one of my movies to AC3 (DD). I want the best quality possible but I also want it to be compatible with a lot of DVD players. I have been told that I can use BeSweet. is that the best program or is there something better? on one of the guides I have seen, it says that the .ac3 files that BeSweet makes aren't compatible with some Pioneer dvd players. again, i'm looking for best quality.
That incompatibility stuff was ages ago.
Both ffmpeg and BeSweet use the same AC3 encoder and although there are no longer any compatibility issues the quality is definatly not the best.
For better quality you might want to try TMPGEnc's AC3 encoder, the one that comes with Scenarist or even SoftEncode. -
hmm.. ok what about the DVD Authoring program, Sonic DVDit!, that has a convert to AC3 option, is that any good? and on a side note, how good of an authoring program is it?
Softencode isn't sold anymore, so the legality of aquiring a copy is dubious. Sony do sell a very good AC3 plugin for use with sound forge and Vegas/DVDA.
Read my blog here.
Sonic is owned by Sony, so I would imagine their AC3 encoder is very good, no matter what app it's in.
Cheers, Jim
My DVDLab Guides
Difference Between DTS 5.1 & Dolby Digital AC3 5.1
By dorababu in forum AudioReplies: 8Last Post: 31st Mar 2013, 21:31 -
Dolby Digital PLus (ac3) track to FLAC error
By Edgarke16 in forum AudioReplies: 0Last Post: 26th Sep 2011, 23:38 -
Splitting AC3 Dolby Digital 2.0 (surround) into seperate WAVs?
By Asaki in forum AudioReplies: 2Last Post: 29th Apr 2011, 14:18 -
Converting WAV file to Dolby Digital® 5.1 Surround
By roma_turok in forum User guidesReplies: 18Last Post: 16th Nov 2008, 22:32 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54
