I converted one of my dvd-rips into an mpeg. The resolution that i choosed was 704 x 480. when i dragged it into a super vcd or vcd window of nero, it says invalid resolution. so am i stuck with the 3xx X 2xx resolution? Does the resolution even matter or its only the bitrate that matters.
If you want to be able to make a VCD or SVCD then the res has to be 352x240/288 (VCD) or 352/480x480/576 (SVCD). You can't choose anything else. The resolution you choose also has to be the correct one for the format you are encoding to - eg. 352x240 for NTSC and 352x288 for PAL etc.
Youtube HD Resolutions
By bseos in forum Video Streaming DownloadingReplies: 12Last Post: 14th Oct 2011, 10:50 -
Screen Resolutions
By ranosb in forum Video ConversionReplies: 4Last Post: 25th Aug 2009, 02:04 -
Capture resolutions?
By visionman in forum Capturing and VCRReplies: 6Last Post: 28th Jan 2009, 12:13 -
Question about resolutions
By ShinKyo in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 08:44 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 12:42
