  1. I am trying to figure out how to setup TMPG to go back to the track menu after a track has been played.I tried different combinations with no luck in the menu display settings.I created 8 tracks on a DVD.I just have the track menu displayed with NO menu.When a track is done I want it to go back to the track menu I created.Can anyone tell me how to set up the menu display settings so after a track is done it goes back to the track menu page?.
    Also is there is a way to play track #1 and when it goes back to te track menu have it automatically highlights track 2 and so on?.
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    I assume you're referring to TMPGEnc DVD Author (TDA). It is not possible to do what you want using TDA alone. But you can use PgcEdit to edit the ifo files after your menus are made with TDA to accomplish what you want.
    Buy My Books
