  1. After I rip a DVD and convert it and everything through TMPGEnc, I play it back and the sound quality is very low. It sounds ok, but I have to turn my volume almost all the way up to hear it good enough. Any suggestions on how to fix this?
  2. when you open in the first time the DVDx you have a section their under the name "volume" put the number 5 insted of 3 or 0 that is writen in their
  3. Click on Settings, under the advanced tab select Audio Effects. Increase the audio as much as you like; I use 200%. I also select Normalize in DVD2AVI.
