I bought the Sony DVD +/- recorder RDR-GX300. According to it's manual, it can't recognize 4x DVD-RW media, which I read too late. The 4x DVD-RW media are not backward compatible to the older 2x DVD-RW media. See (on pages 8 and 9):
http://www.docs.sony.com/release/RDRGX300revision.pdf
I prefer DVD-RW VR because with DVD+RW the Sony recorder can't record the 16:9 wide screen flag from digital settop boxes and does not allow to set manual chapter markers. What to do, if in future 2x DVD-RW media are discontinued and will be no longer available?
Does anyone know, if the internal DVD drive of the GX300 can be exchanged against a newer model or if the firmware can be updated?
Good luck getting Sony to update your firmware. It isn't posted on their Web site, nor has firmware ever been. Perhaps you could call a Sony repair facility and ask your questons.
Also, you could void your warranty if you rip out the old hard drive, and have operational problems if you're a novice.You're never alone with schizophrenia. -
Why does everybody assume this?Originally Posted by joeg04
You know... you can find 4x CD-RW media still
You can buy 1x DVD-RW stillWant my help? Ask here! (not via PM!)
I assume that 2x DVD-RW media will be discontinued, because demand for it will be too low to be interesting for producers of DVD media. All future PC burners and DVD recorders will support 4x DVD-RW media and only a few old DVD recorders that can't be updated are in the market.Why does everybody assume this?
There is a difference to DVD-RW media: Writing to high speed CD-RW media is not possible below 4x speed. So standalone CD audio recorders need 1-4x CD-RW media because they record in real time and that means at 1x speed. So there will be forever a demand for low speed media.you can find 4x CD-RW media still
A standalone DVD recorder without HDD records at 1x speed or even slower, dependent on the recording mode. Recording at 1x speed or slower is possible with 4x DVD-RW media, if this media is supported by firmware. So future DVD recorders don't need slow DVD-RW media while future CD audio recorders do need slow CD media.
I think not forever.You can buy 1x DVD-RW still -
As I wrote above, the DVD recorder Sony GX300 can't record to 4x DVD-RW media.
I read, that the Sony RDR-VX500 contains a NEC ND-2500A burner:
http://club.cdfreaks.com/showthread.php?t=136514
So I guess, the similar GX300 contains the same burner. The media list of NEC shows, that the ND-2500A with actual firmware can burn 4xDVD-RW media:
http://www.de.nec.de/software/1579_Media_List_for_8x_DVD_Writer_(1.07).pdf
So my idea is to take the NEC burner out of the GX300, plug it into a PC, update firmware and then plug it back into the GX300. Goal is to enable the GX300 to burn to 4xDVD-RW media.
Does anyone know, if the GX300 will work if it contains a burner with updated firmware? Or if it has a burner with non-standard firmware?
Thanks. -
Here's an idea:
Stock up on Pioneer 2x media now as low as $0.51 each in 100-pack:
http://www.meritline.com/pioneer-2x-dvd-rw-media.html
I wouldn't assume that till I actually took the lid off.I read, that the Sony RDR-VX500 contains a NEC ND-2500A burner. So I guess, the similar GX300 contains the same burner. -
I've had the Sony RDR-GX300 since last November, and I have recorded well over 200 DVD's onto 4x discs or higher with no problems.
It can't hurt to try one....
On Edit: Most have been DVD-R's, but I have recorded a dozen or so DVD-RW 4x with no problems...
Sony HDR-XR160 I want to live record to a DVD recorder with quality picture
By Sparkiewalt in forum Newbie / General discussionsReplies: 13Last Post: 29th Mar 2012, 08:40 -
Sony dvd recorder model RDR-GX300 cannot play/record discs
By hdubya in forum DVD & Blu-ray RecordersReplies: 1Last Post: 26th Aug 2011, 03:40 -
CRT TVand Sony recorder HDC500 can't watch and record in HD Help
By Glasswitch in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2010, 01:34 -
Sony RDR-GX300 DVD Recorder can't record channels 200+?
By showmi in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th Jul 2008, 15:49 -
DVD Recorders (VHS to DVD Recorder then record raw footage and finalize)
By aeafisme23 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 16th May 2008, 14:39
