question: i have a divx file (ghosts of mars) that i try to convert to vcd
1. when loading in the windows media player it plays okay
2. saving audio stream to wav file using vdub
3. wav file that plays correctly in media player but...
4. can't be read by (for example) cool edit (causing strange noises)
i suspect a codec or cooledit issue, any suggestions?
What's the sampling rate and resolution of the wav file after the conversion?
solved the problem, it was cooledit! couldn't handle certain types of mp3... acoustica did the job properly, first time cooledit lets me down, well, one learns something new everyday...
the raw extracted sound is reported as a windows pcm 48khz 16bit stereo, but it isn't
... and things get even better, after conversion using acoustica (not saving it, just starting up acoustica, converting, no save and close) now cooledit does the job as well... must be something on the codec side that is not properly handled by either cool edit or windows or... oh what the heck, it works
Extracting audio from a 3gp file
By berfles in forum AudioReplies: 2Last Post: 17th Nov 2011, 10:54 -
Extracting Audio From MP4 File Help Please :(
By MyKool Buble in forum Video ConversionReplies: 5Last Post: 3rd Mar 2011, 12:36 -
Extracting Audio - Voxware RT29 Codec
By Killer3737 in forum AudioReplies: 1Last Post: 3rd May 2009, 15:06 -
extracting multiple audio from DIVX
By Radixmind in forum Video ConversionReplies: 3Last Post: 7th Dec 2007, 08:31 -
extracting audio from m2v file
By matneaves in forum AudioReplies: 1Last Post: 30th May 2007, 16:56
