  1. Converted avi to dvd using mainconcept.
    Extension is mpg file
    What to use to conver mpg file to the typical dvd structure (vo, ifo, bup extensions)
    Thanks !
  2. You need to "author" this .MPG file. The guides are over on the left-hand side of your screen.
    I'd suggest TMPGEnc DVD Author to begin with - it is user-friendly and won't break the bank if you like it!
  3. Thanks Cobra, used the program, burned to a DVD RW and the result is great.
