When converting my avi file to Mpeg2 it seems to be ok with Tmpgenc plus, it indicates at the bottom of my screen (MPEG-2 720x480 29.97fps CBR 8000kbps). But when I verify with AVIcodec it shows me Mpeg-1. When I check some of my Mpeg work from the past using AVIcodec it clearly indicates Mpeg-2. What am I doing wrong? I recently updated to the New Tmpgenc plus.
Results 1 to 11 of 11
Your a genius..that's it
But I thought Mpeg 2 was the quality of video and the audio had nothing to do with Mpeg 2. So basically are you saying only video would be Mpeg 1? Am I getting this right?.. this doesn't sound right I'm confused.. -
It is a matter of multiplexing. For example multiplex audio and mpeg2 video in TMPG selecting the "MPEG1 VCD (non-standart)" in MpegTools and the output will be recognised as mpeg1 because the mutiplexer re-write the headers of the video file. I have used quite often the opposite approach - encoding mpeg1 in TMPG and mutilexing as SVCD in bbMPEG with two audio tracks (VCD can have only one audio) and after that multiplexing subtitles with WinSubMux (it recognises it as mpeg2 file!) and authoring and burning the SVCD in VCDEasy - recognised as mpeg2 file aswell. My player has no probs with such a SVCD.
Then maybe some settings in TMPG are not correct - I see from your first post you are encoding for DVD. Well, I don't know what can be wrong - if you load DVD template everything should be OK.
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 08:46 -
Curious questions about AVIcodec & GSpot
By AKA009 in forum Newbie / General discussionsReplies: 5Last Post: 13th Oct 2009, 18:51 -
TMPGEnc Plus converts AVI to MV2 instead of MPEG movie
By buzzsaw in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2009, 19:36 -
Figuring out why this AVI file crashes MPC & AVIcodec
By DRP in forum Software PlayingReplies: 14Last Post: 11th Nov 2007, 21:19 -
AVICodec reports wrong frames per sec
By igorek in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2007, 20:27
