Capturing analogue video, but files get huge if I want the best quality.
2 minutes of video takes 450 MB, output is an avi files.
It depends on what you plan to do with the video and what software and hardware you have. From the file size it sounds like you're capturing from a DV camcorder. If that's the case, the file sizes you're getting are normal.
If your final destination is DVD, if your software supports it, and if your computer is fast enough, you can try converting to MPEG2 while capturing.
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 15:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
BD Codec?
By kinglerch in forum Blu-ray RippingReplies: 4Last Post: 1st Aug 2008, 21:26
