hey everyone, a little survey, please take time to fill out, you may just list your answers. thanks you.
Results 1 to 30 of 62
Wow! You got shocks, pegs... LUCKY!
thanks very much for takin time to do this.
Wow! You got shocks, pegs... LUCKY! -
You can add more images by editing your original post.
Answers will be PMd shortly. -
thanks, i appreciate the advice
Hello,
Could you make it a "fillable" adobe pdf file??? You might get more reponses if all people need to do is download the file - type in the anwers - and email it to you. Just a suggestion. Good luck.
um ok, could you perhaps tell me how, is it possible with a picture file?
Hello,
I guess you need a real version of one of the adobe products. Or you could just upload the .doc or txt file to make it easier to fill in.
should i just upload a word doc?
Hello,
That would work - then either the taker could reupload or give a junk email address you don't care about and they can email the completed form to you. (junk so its not spammed to death if you use it reguarly).
Kevin
(I think there are free .doc readers if people don't have OFFICE right????)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
ok ill upload DOC and TXT, that should be good, could you explain to me how to upload those files?
We use this so it might work...Originally Posted by yoda313
http://www.microsoft.com/downloads/details.aspx?FamilyId=95E24C87-8732-48D5-8689-AB826...displaylang=en -
Hello,
Same as a picture file you upload:
Just make sure the file name isn't capitalized or has any spaces in the filename - for some reason php doesn't like those.
question 4 on page two is badly worded in that you are lumping two things together to get a false answer ..
its a loaded question
here are the two pages with check boxes added in pdf .. (a "fillable" adobe pdf file)
see here
https://www.videohelp.com/forum/viewtopic.php?p=1251042#1251042"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
you are welcome
Hello,
Whats up with the security bj_m???????? File won't open....
This whole questionnaire gives me a fishy feeling. What is it for?
Also, the layout of the questions is inconsistent. For example, the first question asks if the government has the right to view IM, but then asks for a quantitative response (i.e. a scale), then later on the last question on page one, it again asks if the government has the right to watch comp files w/o a warrant but instead wants a qualitative response (yes or no).
Then on question 5 for public surveillance it is essentially asking if spending should be increased for public surveillance to improve security. That is loaded. What if you answered the previous question (#4) with "Not at all". Question #5 assumes you believe that public surveillance increase security."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
whoops - really?Originally Posted by yoda313
the security was only for form fields dont get moved around ...
ill remove all security"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hello,
Yep - must be set for mods only eh????
Kevin
EDIT _ oh got it now -
- locked for editing purposes
i agree that many of the questions seem ameteur, but i should have revealed the whole reason why i posted this survey. my son has an assignment due in class, to get 30 surveys filled out. the questions were created by the students. they are studying how surveys affect governmental decisions. i understand that the questions could be better, but i dont believe the students understood how they wanted to ask the Q's, so please bear with it thanks.
That makes sense, if its just a school project I can understand.Originally Posted by skip2mylou"A beginning is the time for taking the most delicate care that the balances are correct."
i have uploaded the
TXT
surveillance-survey.txtWow! You got shocks, pegs... LUCKY! -
yea - it opens ok -Originally Posted by yoda313
you had me worried (as i lock and sign a lot of pdfs)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i had already made it a form for you above -- al you have to do is check the boxs and email it to you .....
much simpler"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
and the
DOC
surveillance-survey.docWow! You got shocks, pegs... LUCKY! -
o thanks BJ_M, honestly ur a BIG help, thanks
doesnt open
anyway -- see my post above for a much cleaner method"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
BJ_M how come i cant open the PDF?
Best way to convert a .dv file to an .avi file is...... Survey says ???
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 3rd Feb 2010, 22:39 -
external USB HDD and standalone player Survey
By nalooti in forum Portable VideoReplies: 0Last Post: 18th Dec 2007, 04:30 -
Survey about future features in Adobe Encore
By EncorePM in forum Authoring (DVD)Replies: 0Last Post: 27th Aug 2007, 15:13 -
CD Freaks ANNOYING BLOODY SURVEY POPUP
By Anonymous4374945 in forum ComputerReplies: 16Last Post: 18th Jul 2007, 18:43 -
Capturing Analog Video: Device Options (Survey/Questions)
By SHVideo in forum Capturing and VCRReplies: 6Last Post: 12th May 2007, 20:19
