hello everyone,
i have a few games on my computer which take up quite some space. so i decided that it would be a smart choice to move them to CDs. however, my games are the ones that you save your progress as you go, and when i burn all the files to CD, the settings folder gets burned, and i am not able to save anymore. so is there any way to keep the settings folder on my comp, so that i can save my game, and still have the settings load in the game?
Results 1 to 9 of 9
Wow! You got shocks, pegs... LUCKY!
Why not just upgrade your hard drive? 200g ata100 WD at newegg for $96. That price is simply unbeatable.
Boy do I love my avatar! -
i guess, but i just wanted to explore more options than just upgrading. thanks though.
Wow! You got shocks, pegs... LUCKY! -
well @ skip u mean 2 keep settings folder on my comp and when u play game from cd the game shud load with the settings i don't think its possible m8 u must keep the complete game on hdd or just keep updating the settings folder on ur cd by some means if ne burning software provides such option which i doubt.
o ok thanks. that makes sense, and i knew that those were the only possiblities, but i was just wondering if there was a way. if not well then... thanks anyways
One possibility is to put shortcuts on the CD to the files that you want to keep and update to your harddrive. I know this will work when reading the files, not sure about saving though. You could give it a try using CD-RW disc.
EDIT: I just did a test. I created a simple text document and saved to a folder buried down in my user documents. I then created a shortcut to that document and put it on my harddrive. I then open the shortcut in word and added some text and re-saved it. It update correctly. I made sure that the shortcut title matched the document title exactly. -
just a sugesstion, if somehow you could modify the game files to save to a diff. place than what its deafult at?
m8 did ya add the shortcut i think that works on hdd not on a cd maybe u can try on a cd rwOriginally Posted by rkr1958
@ skip when ya burn ur cd with saved games just create a virtual drive or somethin and just update the saved games folder and burn everything on cd rw.m8 ur avatar is kewl could u send it 2 me
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:16 -
Computer Guys Braggin' Time: What have you built that AIN'T a computer?
By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 15:19 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 12:06 -
Capturing Halo 3 gameplay from computer monitor to computer
By Jamo in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 00:06
