My brother has given me his wedding DVD which only runs for about 20 mins(plenty of room left on disk). He has also given me 100 or so digital pictures and wants me to make a new DVD with the existing wedding video footage and a picture slideshow.
Is this easily done?
How would one best go about it?
Thanks guys.
Results 1 to 10 of 10
~Firefly - Keep Flying~
If you want to do it with freeware then...
First you have to rip the mpg off the dvd, you can use DVD decrypter to do that.
Then you can create a slideshow with DVD slideshow GUI, and export to m2v+ac3+chapterpoints.
Then you can use Gui for Dvdauthor or DVD author GUI to import the video and the slideshow and set it op with menus ect.
And the burn with your favorite dvd burner proggy.
Have fun,
Tin2tin -
MemoriesOnTv is another solution (although it's not free and you would need the DVD Plug-in with it) once you've ripped the mpg. Just add video, slides, music, and narration.
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776 -
To creative slideshow Photodex Proshow Gold its the BEST!
You have 277 transmission effects.
With out to everything.
Tin2tin,
How do you rip to mpg from a DVD using DVDecrypter?~Firefly - Keep Flying~ -
Maybe the later part of this gude can help you:
https://www.videohelp.com/forum/viewtopic.php?t=224833 -
I would also recommend Slideshow Movie Maker for making slideshows, its a great piece of freeware that produces excellent results!
Photo2DVD Studio has worked well for me. It is very easy to use and has a wonderful slide show.
Adding selectable subtitles to an existing dvd with a mac
By chiappa in forum MacReplies: 5Last Post: 17th Mar 2012, 21:00 -
Adding existing menu to DVD
By PirateAhoy in forum Authoring (DVD)Replies: 0Last Post: 29th Sep 2011, 13:53 -
Adding Menu to Existing DVD
By HamishT in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2011, 16:23 -
Adding/editing subtitles to an existing DVD without re-authoring?
By frankiewode in forum SubtitleReplies: 1Last Post: 2nd Nov 2010, 20:43 -
Adding English subtitles to existing DVD on a Mac?
By Eug in forum MacReplies: 5Last Post: 29th May 2010, 18:13
