MacTheRipper 2.6.6 was just released with the following improvements:
•*Improves prescanning to fix crashing problems on certain DVDs
• Faster prescanning by consolidating code into fewer passes to reduce seeking
Grab your copy here:
http://www.ripdifferent.com/~mtr/download.php?id=3
Results 1 to 10 of 10
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
Using it right now, seems great as always.
Thank you very much for this piece of software. -
Wender--
the files are probably modified due to RCE, or Region Coding
being re-set. I'm not to sure, but de-Macrovisioning it
wouldn't modify the IFO? WW or GB would know though...."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
right first I have to do this....
MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN MOAN !
right that will keep all the people who say im a misrable git happy.
Yes TJ you are correct , they get patched for UOPS , Region , RCE , and creator data.
Then again , it sounds like toast messing with your ifo's...
GB -
No - I meant they are changed by Toast. Doing a compare between the ripped files on the hard drive and the burned DVD always tells me the .ifo and .bup files are altered by Toast.Originally Posted by terryj
They are probably altered by MTR in the first place, but burning those altered files with Toast shouldn't make them change (again) ? -
does the version support the new file of encyption used on RE:Apocalypse? I too, thank you for all your hard work...
ScottZ -
What a smokin' little application!!!! Thanks for the work, GB. Your making me look like a friggin' genius with my wife, and the saving of her original dvd's.
Drake
MacTheRipper - couple of probs
By satcure in forum MacReplies: 3Last Post: 24th Aug 2010, 15:44 -
confusion with mactheripper, perian & handbrake
By yoly in forum MacReplies: 4Last Post: 7th Feb 2010, 03:48 -
MactheRipper - Solutions and alternatives?
By JonnyPhoenyx in forum MacReplies: 1Last Post: 4th Mar 2009, 13:41 -
MacTheRipper/Popcorn
By monieeka in forum MacReplies: 3Last Post: 21st Jul 2008, 03:39 -
Single vob file in MacTheRipper?
By bmoney017 in forum MacReplies: 2Last Post: 20th Oct 2007, 03:07
