xp2800+ and pc3200 corsair value select 2.5 3 3 8
everything seems to be stable... idles around 46-47C and under load 52-53C so i think i did it right![]()
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
Looking good! Is this the maximum you can attain?
If you want to go faster, drop the CAS latency to 3 cycles. Might help. Also, make the RAM 1:1 with the FSB. -
yeah i know i figured that out late last night
the ram is 1:1 now 180mhz and is running 2 2 3 5
i might try and OC it a little more. more than anything im worried about heat with the summer month coming up though
btw you dont think 2.5 cas will fly?PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
No, raise CAS to 3 if you want to continue. 2 is an extremely tight latency.
that's just what im at for right now and it's stable. yeah if i go higher i'll bump it up
2.5 won't work at a little higher speed?
i was at 2.5 3 3 6 when the ram was running at 225.5 and it was stable -
ok so at lunch break i went and grabbed a couple of fans....80mm 52.8 cfm to replace the one on the heatsink thats running at 34 cfm. and a 120mm 57.48 for the front. and antec has whatever on the back(not sure but it's antec so im not worried)
so when i get my asus a7n880 on monday i'll install everything and see how far i can push it
