  1. Member Ma_Jie's Avatar
    Jan 2005
    not America
    Hi guys. Does anybody have experience with this media?
    I know it's probably shit, but I can get 50 IJP (inkjet printable) discs for $15 CDN.
    Any comments would very much appreciated,
    THX,
    MJ
    (1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
    (2)Philips 8631 @ BenQ1620 w/ B7U9 w/ MCSE speed patch
    GET MCSE HERE
    BenQ Ownz j00
  2. Looks pretty bad judging by the media reviews:
    https://www.videohelp.com/dvdmedia.php?dvdmediasearch=onidtech&dvdmediadvdridsearch=&ty...+or+List+Media
    I've used the VDSPM...whatever the hell it is, they actually burned decently, but I think they may have been shady near the edge of the discs, like most cheap media typically performs. I don't have any more to test unfortunately, though, and I only had a few to begin with. Probably not worth the trouble unless they're significantly less than anything else, then maybe try a few and see how they do on your burner.
  3. Member Ma_Jie's Avatar
    Jan 2005
    not America
    Hi steve.
    Thanks for the reply! I was just considering them b/c my current spindle of MXL RG03s is running out, and I need some discs to tide me over until they put the Maxells back on sale.
    I'll see if I can buy a few, and I'll test them: according to MCSE, the BenQ does support them.
    - MJ
    GET MCSE HERE
    BenQ Ownz j00
    Originally Posted by Ma_Jie
    it's probably shit,
    Yes.
    for $15 CDN.
    After you throw away coasters, it may be $1 per disc.
