I copy shows using my tuner, and then encode them to a dvd standalone playable format to play on my dvd player. What's the best way to fit as many episodes of a show on ONE dvd? The best way i know of right now is to make them vcds...
Hello,
That is one good way. Another would be to make them into divx then you can squeeze even more. Depending on whether or not your stand alone plays divx of course.
Or use halfd1 and chop the bitrate way down you might be able to fit six hours or so on the disc. But quality will suffer. With media so cheap these days (for single layer) why suffer??? Just put less on per disc and preserve the quality as much as you can. You could get a dvd disc changer if it bugs you a lot to switch discs
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
A Holiday Season Shoutout To All
By budwzr in forum Off topicReplies: 15Last Post: 28th Dec 2011, 23:44 -
Need help mapping season episode to grouped chapters on a DVD
By nzdreamer55 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2010, 17:12 -
Audio on Entourage Season 1
By Swordfish34 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 13th Mar 2010, 15:31 -
a complete season of a tv series on a 4.7 gb dvd
By Sanmaame in forum Authoring (VCD/SVCD)Replies: 2Last Post: 2nd Feb 2009, 20:44 -
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 01:23
