I have some widescreen material that I'm putting onto DVD. The material has some occasional hardcoded subs that when I view it on the TV, the subs goes off the sides of the screen. Is there a way to keep the subs on the screen and at the same time, keep the widescreen?
In TMPGEnc, the settings I used to convert the AVI to M2V was:
Aspect Ratio: 16:9 Display
Source Aspect Ratio: 16:9 525 line (NTSC)
Video Arrange Method: Full Screen (keep aspect ratio)
Results 1 to 11 of 11
Do I need to add 16 pixel borders to the height? I'm not sure what I'm doing here.
Is this okay:
Center (custom size)
736x480
In the Preview, there doesn't seem to be any extra borders though. -
If your original size is 720x480 then make it 704x464 in the center(custom size) setting.
How did you get 684x464? :P What's wrong with 688x480? Also, if you know anything about Xvid and the decoder lag error in Vdub, do you think you can help me with that too? I didn't bother to create a new thread so the first post of the thread isn't by me. My problem is in my latest post in that thread:
https://www.videohelp.com/forum/viewtopic.php?t=258552 -
688x464 i meant,when you reduce the size down that way it adds black borders to bring it back to 704x480.You need to subtract 16 pixels from all sides to keep the aspect ratio.
What i do is use nics 4cc changer and change the xvid header to divx,gets rid of that first frame error message.I think,therefore i am a hamster. -
What do I set the "Description Code" and "Used Codec" to? I selected DIVX and XVID and then tried interchanging them but still it doesn't work. Either the error is still there or the AVI cannot be played.
My source AVI has no errors. It's just that the error shows up whenever I open the AVS script. I saved that as an AVI and the error frame was saved as well. I applied the 4cc change to that saved AVI.
Set both to divx,then it will work.
It's still not working. I tried to apply it to the original AVI and then run the AVS script but no, the error is still there.
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 12:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 21:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 23:15
