  1. some how i can't play avi with my wmp not even with bsplayer... there sound but no picture...so i uninstall the k lite codec pack and re install it...i was able to play avi but very choppy...then the mpeg file can't not play...i think there something wrong with the codec but i don't know what to do...can some one hlep me pleas...
    USA
    The K-Lite codec pack is most likely at the root of your problem. When you install a whole bunch of codecs, the odds are some will conflict. Happens all the time. You can clean out the problem ones with Codec Sniper. Uninstalling K-Lite may not remove them. Check the videos with AVIcodec or Gspot to see which codecs you need and ONLY install them.
