I'm trying to figure out which encoder to use on AVI files which are MP3 in their original source. I have always used MPEG audio since that's what CCE will output after converting the AVI audio to WAV. I have never had a problem with MPEG audio even though it's never been part of the standard for NTSC. As a matter of fact, I've been shocked that I have yet to find a player that wouldn't play MPEG audio. Yes, I know they exist but none of my friends or family had any problems.
Anyway, just to make my stuff more "in spec", I decided I should encode with AC-3 2.0. I made a 15 minute test disc. I did everything the same as usual except this time I encoded the WAV audio to AC-3 2.0 with FFmpegGUI. Then I muxed everything together as normal.
I got a rather weird result.
The first time I put the finished disc in the player...No sound at all
The 2nd time....sound played fine all the way through
The 3rd time...sound played for about 90 seconds, then dropped off and never came back on.
The 4th time...sound played fine all the way through.
So now I'm trying to figure out the source of the problem. Perhaps I had a wrong setting in FFmpegGUI (I used 192 bitrate, 48000 sampling rate). Or perhaps this is the incompatibility problem I've read about after doing some searches here. I read that BeLight is now "in-spec" so perhaps I should try that. I just used FFmpegGUI because it seemed to be what most of you are using.
Maybe I'll just go back to MPEG audio since it seems to work, but I'd like to encode AC3 since I might need it at some point in the future.
Anyone have any thoughts?
Hello,
Try different blanks. If it works sometimes but not others it might be a bad batch of dvdr's.
But yeah MPEG audio works just fine in NTSC players. My hauppauge wintv pvr250 only records in mpeg audio and I've never had a problem.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Anyone having JVC GZ-HD7 .TOD file conversion problems/compatibility
By Gtoll in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 67Last Post: 10th Mar 2016, 10:18 -
dts to ac3 problems
By scarlac in forum AudioReplies: 5Last Post: 23rd Apr 2010, 03:41 -
Windows 7 AC3 Problems
By eon_designs in forum Video ConversionReplies: 3Last Post: 20th Apr 2010, 05:07 -
Ac3 Downsampling problems
By robbynaish in forum AudioReplies: 1Last Post: 27th Jan 2010, 18:33 -
Problems with PS3 Compatibility
By AjzRide in forum Blu-ray RippingReplies: 4Last Post: 30th Jul 2009, 09:32
