ffmpegX used to convert a 660 meg or so avi file into a 1.7-2.2 gig DVD, now it insists on using 4.5-6.0 gigs. I'm using decode with mplayer, and both the ffmpegX and mpgenc encodings. I tested an old avi that I had converted back at 0.0.9b or c, and the DVD was 1.73 gigs, that same avi file with the same settings now produces a 4.93 gig DVD.
This is very weird.
WHEN'S VERSION 1.0 COMING OUT!!!!
No specific changes have been occurred to mpeg-2 encoders recently. You should try using "ffmpeg DVD" with "best" bitrate and "Decode with Quicktime" disabled.
converts to dvd but its always to big
By dylanvega123 in forum Video ConversionReplies: 3Last Post: 5th Aug 2009, 17:53 -
dvd way too big?
By item9 in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2009, 00:41 -
Why are my AVI2DVD dvd ISO files TOO BIG to burn onto DVD!?
By Xenogear900 in forum Authoring (DVD)Replies: 5Last Post: 1st Sep 2008, 21:20 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51 -
DVD to one big VOB ?
By rindless in forum DVD RippingReplies: 5Last Post: 19th May 2007, 04:42
