  1. Banned
    Aug 2004
    i have a BenQ DW1620 bulk version dvd burner with the firmware version G7Z9. i see that there is another version that is G7K9. i would like to know which firmware version is the newest.[/b]
  2. Member Ma_Jie's Avatar
    Jan 2005
    not America
    Go to the U.S., BenQ site and DL G7P9...or alternatively, cross-flash your drive to the B series of FW, e.g., BP79 or BT79, or BU79...go to the CDFREAKS BenQ/Philipus forum for more info on cross-flashing.
    MJ
    (1)BenQ 1620 w/ B7u9 w/ MCSE speed patch
    (2)Philips 8631 @ BenQ1620 w/ B7U9 w/ MCSE speed patch
    GET MCSE HERE
    BenQ Ownz j00
  3. Banned
    Aug 2004
    what would be some advantages of cross-flashing to the "B" firmwares?
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    http://dvdpro.club.st/firmware/BENQ_FW.htm
    use that link i provided to download the firmwares. you can cross flash the drive by downloading the WINDXFLASH.EXE and B7P9 cvt file if you want to cross flash the drive to the B firmware series. make sure you have no media in the drive, turn off all programs running in the background like antivirus software and you can flash the drive in windows or in safe mode. double click the WINDXFLASH.EXE then direct it to the B7P9 cvt file reboot the pc when the flashing is done.
  5. You can also use G7T9 although it may have problems with cd-dvd speed.
    ftp://62.101.64.70/dvd-rw/firmware/dw1620a/bulk/g7t9.zip
    http://buan.nu/benq/dw1620/G7P9.zip
    but in the G series either P or T are the best of the bunch.
