Well, I don't have a wide-screen TV, and it's only 27". I'd like to view my Xvid's on full-screen, instead of wide-screen. Is there anyway to do it?
Method 1.
You need virtualdubmod (not the regular virtualdub).
Open virtualdubmod, click File, open, and browse for your movie, click OK.
Now click Video, filters, Add. Click on Resize.
The new width and height are going to be exactly what your source is, otherwise the video will get squashed.
Put a tick mark in "Expand frame and letterbox image".
The two most common (for NTSC) are 320x240 and 720x480. Don't resize too much!!! If your source is 352x150 or thereabouts, then in the Frame width box, put 320, and in the Frame height, put 240.
Keep the fill color black, unless you WANT blue or red bars on the top and bottom.
Click OK twice, and you'll see the result in the right hand pane.
Click on File, Save avi.Cheers, Jim
My DVDLab Guides
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37 -
converting wide screen to full screen. HELP!!
By arjunkkalra in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 13:41
