I have a divx file which i need to be able to fit onto a cd but it is just too big to fit on the cd. How can i compress the divx to make it smaller. I am sure there is a really simple solution (or at least i hope there is).
Results 1 to 11 of 11
Recompress it with a lower bitrate with VirtualDub or some other program.
A quicker solution is to cut it in half with VirtualDub in "direct stream copy" mode. Put it on two CDs. -
the annoying thing is that it is only about 710 MB. i had thought about simply zipping it but i thought i might as well make the movie a bit smaller, as i am giving it to someone, who will prbably not want to have to unzip it each time.
i tried with VirtualDub, but i tried to use the Compression option under Video and selected Divx but it wasnt having any. i will try with just changin bitrate straight off. -
just tried bitrate changing using DviX 5.2 or something and it says "The source image format is not acceptable (error code -2)". dunno what that means
Hmm, did you try overburn in the burning application? Should work if your burner support overburn.
Alternatively you can use an utility called mode2CDmaker. With it you can fit 800 MB divx/xvid avi at 700 MB CD. Though for playback you should install riff CD/XA filters for XCD. -
i have roxio easy cd creator 6. some sites says it supports overburn and some says it doesnt. either way i dunno how to use it. i would rahter find a way without needing to install new stuff on any computer that it may be used on.
yeah i know about the need of divx codecs. what i meant was that extra thing that was mentioned to run the cd when that other program is used. i'll try the audio bitstream
use virtualdubmod or nandub in direct stream copy and cut off the end crecits to shrink file
http://nickyguides.digital-digest.com/join-split-avi.htm
alternatively use overburn on nero
How to compress DV avi
By marti252 in forum Video ConversionReplies: 12Last Post: 7th Dec 2009, 03:12 -
how to compress Avi Divx in Vobsubmod?
By Dboyz in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2009, 01:03 -
Can i compress a
By YOURCONNEXX in forum Video ConversionReplies: 4Last Post: 9th Dec 2007, 13:03 -
is it possible to compress HUFFYUV?
By Lee82 in forum Newbie / General discussionsReplies: 3Last Post: 10th Aug 2007, 13:56 -
How Do I Compress a File?
By The Monkees in forum Video ConversionReplies: 3Last Post: 11th May 2007, 18:38
