I've exported a Microsoft DV AVI file using Premiere Pro. When I try to encode it using TMPEnc Plus all I get is black video. Does anyone know the cause of this? Thanks!
you sure you didnt save it as a mainconcept DV file ?
thats what adobe now uses - unless you selected microsoft dv (which looks like crap)
in tmpgenc anyway -- adjust the vfapi priority settings for avi higher ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Is there any way to use Huffyyuv in Pinnacle Studio for capturing?
Also, can this format be used when exporting from Premiere?
Encoding a vob file to use in premiere pro
By spongela in forum Video ConversionReplies: 2Last Post: 17th Oct 2011, 18:31 -
Basic questions on Premiere Pro, Authoring, Encoding...
By nharikrishna in forum Authoring (DVD)Replies: 4Last Post: 11th Oct 2010, 00:49 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Encoding for uploading YouTube. Best settings with Adobe Premiere Pro 1.5?
By vid83 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Dec 2008, 19:27 -
Premiere Pro encoding preset - Can't find it - Pls help!
By slinky005 in forum Video ConversionReplies: 1Last Post: 26th Sep 2008, 13:21
