Perhape there is a logical answer out there ?
every time i encode to miro or lingos...vcd or mpeg 1 i get digital green flashes...espically when i edit pieces together on miro dc 30 using any encode they offer...also the same problem...the grean can move around if i change some of the encoding info...but i cant get it out. I can however encode direct from AVI to VCD through Nero or lingos...but i cannot edit segments together to make a 74 min file on a disc...the longest i can encode is 49:30 per file...help....barry
Results 1 to 1 of 1
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
GIMP GAP Green Frames
By mixt in forum Newbie / General discussionsReplies: 9Last Post: 25th Apr 2011, 08:45 -
Premiere Pro 7.0 or 1.x problem with green or black frames
By bruce & suzie in forum Authoring (DVD)Replies: 0Last Post: 6th Jan 2008, 11:27 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59 -
Remove green color from 49 frames
By mlong30 in forum EditingReplies: 5Last Post: 10th May 2007, 23:54
