I am using vegas 4.0. My system is a Toshiba Satellite 2410-S203 P4 1.8GHz 768 MB RAM and an external 200GB HD, and NEC 2510A DVD writer.
I have made a 50 minute video project and the final product has small jumps in the video throughout the entire length, there is no problem with the audio. When rendering I turned off all nonessential processes including antivirus. I selected best quality under the custom options. If I select just a short loop section of the project to render the same thing happens, but some other clips like the credits I can edit and render separately and it comes out fine.
Is this a problem in my hardware configuration? Video card? Or something with Vegas? I have been working on this for a couple months now and this is making me crazy.
I tried changing from lower to higher and did a small section - it seems to have worked. Will now redo the whole thing and hope it was the problem. Thanks.
Output Size of PAL VCD Rendered In Sony Vegas Pro 10 Is Too Huge
By LeHuoXuan in forum Authoring (VCD/SVCD)Replies: 8Last Post: 28th Feb 2011, 21:40 -
Sony Vegas 9.0 Has no audio on rendered file
By cowombat in forum Newbie / General discussionsReplies: 3Last Post: 25th Oct 2009, 08:02 -
Vegas AVI 2gig rendered file size limit
By Gargalash in forum EditingReplies: 2Last Post: 17th Nov 2008, 09:12 -
Sony DVD-Architect won't load markers in mpeg file rendered in Vegas
By mltwitz in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2008, 10:01 -
What soft can mux/demux Vegas rendered mpg's?
By Srivas in forum EditingReplies: 8Last Post: 3rd Dec 2007, 05:21
