I just started to get into burning and have encountered something i can't figure out.I have a copy of a movie that someone burned and he burn it onto a Maxell CD-R.It won't play in my DVD player and my DVD shrink program Shrink3.2 won't read it either.Is there a way to convert the disc so i can burn it onto a DVD?Thank you and cudos for agreat forum
Is it a VCD? SVCD? AVI ? Browse the CD and tell us what files you see.
thanks for the quick reply!The files
i see are SVCD,segment,pictures,MPEG2&EXT.Is that any help?The movie is on two discs and i was wondering if i could edit it to put it on one DVD?Thanks again. -
Hmm, if your player is no capable of playing SVCDs there is probability it will be not capable to play svcd content on DVD. One option is to reencode to 352xXXX, but it is not good as SVCD is already quite compressed and you should expect some drop in quality. I would suggest to try so called "VCD header trick" - it can or cannot work, but it is worth to try I think, because there is no reencoding, quality of the video remains the same.
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 06:46 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 01:26
