I have had this problem since i got svcd2dvd.. avi loads fine then starts to convert... either crashes at around 10-15% with an ffmeg error or after a few mins says avi2mpeg done and then compiles dvd thus resulting in a 10-15 min dvd instead of full film.
I have formatted my hard drive and reinstalled and added more ram (now 512 was 256) but still getting this error.. here is the lateset log:
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Name: SVCD2DVD 2.0 RC5
Title: 2.0 RC5
Version: 2.0.1880.30852
Executable: C:\Program Files\BadgerSoft\SVCD2DVD 2 BETA\SVCD2DVD.exe
Executable size: 1.86 MB
Executable size in bytes: 1953875
Executable CreationTime: 23/02/2005 17:10:28
Executable LastWriteTime: 11/03/2005 21:46:37
Executable LastAccessTime: 12/03/2005 08:39:18
************************* Operating System *************************
Operating System: Microsoft Windows XP Home Edition
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 511 MB
Free Physical Memory: 307 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.96 GB
***************************** Computer *****************************
Computer Manufacturer Name: MEDIONPC
Computer Model: AWRDACPI
System Type: X86-based PC
Computer Name: xxxx
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: xxxx\xxxxx
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Pentium(R) 4 CPU 2.20GHz
Description: x86 Family 15 Model 2 Stepping 4
CPU Speed: 2.2GHz
CPU FSB: 100MHz
L2 Cache Size: 0 bytes
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: Medion GeForce4 MX 420
Processor: GeForce4 MX 420
Mode: 1024 x 768 x 4294967296 colors
Video Ram: 64.0 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 29.8 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 32.6 GB
DeviceID: E:
FileSystem: FAT32
FreeSpace: 866 MB
DeviceID: H:
FileSystem: NTFS
FreeSpace: 114 GB
********************* END OF SYSTEM INFORMATION ********************
Processing assets for DVD creation
AVI2MPG: 4704kbs Full-D1
Pass 1/1: Processing hls-aitd.avi
08:39:53: ffmpeg version 0.4.9-pre1, build 4742, Copyright (c) 2000-2004 Fabrice Bellard
08:39:53: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
08:39:53: built on Feb 16 2005 13:01:38, gcc: 3.2.3 (mingw special 20030504-1)
08:39:53: Input #0, avi, from 'D:\films\hls-aitd.avi':
08:39:53: Duration: 01:38:09.8, start: 0.000000, bitrate: 992 kb/s
08:39:53: Stream #0.0: Video: mpeg4, 640x272, 23.98 fps
08:39:53: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 121 kb/s
08:39:53: Output #0, dvd, to 'D:\films\hls-aitd_S2D.mpg':
08:39:53: Stream #0.0: Video: mpeg2video (hq), 720x480, 29.97 fps, q=2-31, 4704 kb/s
08:39:53: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
08:39:53: Stream mapping:
08:39:53: Stream #0.0 -> #0.0
08:39:53: Stream #0.1 -> #0.1
08:44:59: AVI2MPG: done.
08:44:59: Done: Processing assets for DVD creation
Authoring DVD Folders
08:44:59: Creating TitleSet # 1
08:45:16: SVCD2DVD: DVDfolders
08:45:16: Generating DVD folders please wait....
08:45:16: -->: DVDFolders creating VTS
08:45:16: -->: VTS 01
08:45:16: DVD Folders: Processing D:\films\hls-aitd_S2D.mpg...
08:45:16: Finalising DVD...
08:45:16: -->: DVDFolders creating table of contents
08:45:16: scanning H:\dc share\DVD Decrypter Images\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
08:45:16: Finalising DVD...Done
08:45:16: Done: Authoring DVD Folders
As you can see ... process fully completed in 6 mins... can anyone help with this problem???
Any help with be very appreciated.
Results 1 to 10 of 10
After many hours searching net i found this about Data Execution Prevention and problems with programmes .... I have tried it and it still crashes on ffmeg around 18%... it may help someone else though...
I`m still looking for an answer !!!!!!
You can manually configure this by following these steps:
Click Start, and then click Control Panel.
In Classic View, double-click System.
Click the Advanced tab, click Performance, and then click Settings.
In the Performance Options dialog box, click the Data Execution Prevention tab.
Select Turn on DEP for all programs and services except for those I select, and then click Add.
In the Open dialog box, locate and select the application, and then click Open.
Click Apply, and then click OK. A prompt appears and informs you that you must restart your system for the setting to take effect. Click -
DEP should not be an issue any more (since RC3 i think). RC6 should be out today... maybe it won't crash with that. If it does i will take a look at the avi myself.
Just tried again with RC6 ... this time errored at 8% same again FFmeg error, click dont send to microsoft then svcd2dvd carries on and compiles the dvd obviously .. its short...
I think there is something with my CPU causing the problem i have tried vsodivxtodvd and this crashes aswell. i have formatted my cpu reinstalled XP and added SP2 , added more RAM and i`m still getting errors... what else on my Comp could cause this /?????
Thanks -
ok. Can you upload the avi to
ftp://BetaTester:badger@ftp.svcd2dvdmpg.com:7676
i will take a lookSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Could the CPU Temperature be causing my problems ???? Does SVCD use more CPU convertinf AVI files than SVCD ??
Chrissyboy i didnt upload the file because it happens on every avi file i have tried , not only in this program but others... it your program it crashes out saying ffmpeg error ... in others i have tried comp shuts down and restarts..
I came across a program that tells you your temperatures so i checked them .
CPU temp - 40 oc at start prgram not running... when program starts to convert the avi files it gradulally rises...the highest i viewed it at was 83 oc , then had to leave , when i returned it had crashed with the ffmeg error... could the temp of the cpu get to high and that could be what is causing me this problem?????
BTW i have ordered a new heatsing and fan, so fingers crossed when i install them then i will be abnle to use this software with avi`s aswell as svcd`s -
83 oc seems really high to me. I am running an Athlon processor which should run hotter than your Pentium and I rarely see temps above 45C under load. Is your case well vented with plenty of airflow?
EDIT: Yes, there will be more CPU use for an AVI than SVCD, remember that with an SVCD only the audio gets changed and DVD NAV packs are added. Rendering an AVI to another format is very CPU intensive as well as memory intensive. Have you done any other conversions (TMPGENC, CCE, Procoder) on this PC before? -
The case is well ventilated... side is off at moment!! tried that to see if that would work... In the past i have convereted with TMPEG, then all of a sudden it would not work... I have no probs svcd to dvd... just avi to dvd.. recentley i have tried :
SVCD2MPG - crashes on ffmpeg
VSO DIVXtoDVD - crashes and comp reboots
NERO - Occasionally works for short avi files ( TV eps) to vcd other times it crashes and comp reboots
TMPEG - crashes and comp reboots
I really believe its the CPU causing these probs,,, hopefully when i get new heatsink and fan probs will be sorted.. -
I had a similar problem recently. It turned out to be bad frames in the original .avi crashing the encoder. The only cure was to edit out the offending segment before encoding.Originally Posted by all4free
I have checked for bad frames.... and this is not the problem... its with every avi file and every converting tool... these files have been checked on other PC`s... That is why i think it may be the CPU over heating.. Will repost when i have fitted new fan and heatsink to let you know the results
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42 -
MKV file wont playback on TV
By snadge in forum Video ConversionReplies: 7Last Post: 28th Jul 2009, 09:14 -
data avi .hdtv.avi-fqm.wont play on set top recrder
By xbill in forum Newbie / General discussionsReplies: 3Last Post: 15th Jul 2009, 15:55 -
Avi file wont play when playing with .srt subtitle
By cudencuden in forum SubtitleReplies: 2Last Post: 25th Mar 2009, 21:40 -
wmv file wont play nor convert
By excitezone in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2007, 13:56
