Intend to get my very first DVD writer. But I have totally no clue about burning DVD and I couldnt find a guide regarding my problem. So I have 38 videos in RealMedia format each around 130mb / 40minutes. How should I burn them?
If you just want to burn them, then you don't need to convert although 38x130 is a little too large for a single layer blank.
Thanks for the inputs.. If I convert a .rm file to dvd, its too big. (150mb > 1.6gb). Is there other methods?
Kill yourself because RM is from Satan, and if you have nearly 80 hours of RealVideo, you're probably going to hell anyway?
Heh.
You just need to trim down the bitrate, though - you're converting a .RM file, which has astonishingly sub-par bitrate, to DVD resolution but you're also giving it, if each one ends up 1.6GB, to roughly DOUBLE the bitrate of a good quality DVD.
RealMedia/MediaPlayer Classic
By JackPollack in forum Software PlayingReplies: 0Last Post: 18th Jan 2009, 20:36 -
How to Convert Popular Video Formats to RealMedia Files (eg: rmvb)?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2008, 22:09 -
codec for realmedia
By pcb in forum Newbie / General discussionsReplies: 13Last Post: 3rd Jun 2008, 08:47 -
mencoder converting realmedia files w/audio sync problems
By kruuth in forum Video ConversionReplies: 9Last Post: 26th Sep 2007, 16:34 -
Best RealMedia player?
By Brent G. in forum Software PlayingReplies: 1Last Post: 19th Aug 2007, 23:28
