I used Nero Recode 2, I added two 45min videos and clicked fit to target 80min CD
Under Nero Digital Settings, the only option was codec and I chose Real Time Encoding over High Quality Encoding and Burned it...
However my DVD player wont play it, it says disk read error
There is data on the CD though, the videos are .mp4 files and play on the computer.
How do I make it so it'll play on the DVD player?
I understand it has to be an mpeg 1 or 2, not 4, but how to I specify that?
If what you made is a cDVD or MiniDVD - most DVD players do not recognize them. I've made a few myself for laughs.
If it is a CDR with VIDEO_TS and AUDIO_TS folders...that is a cDVD or MiniDVD.
Check them out in the BLUE Glossary section on the left. -
If it says disk read error, then you're out of luck. Your player is seeing a CD, and is trying to find a file structure that it would normally find on CDs. Or vice versa.
Think of it as being like putting a hard drive in your computer that is 20GB, and telling it that the drive is 20MB."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
DVD burning problem
By eunhye in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2008, 20:04 -
DVD Burning problem
By eXit- in forum Authoring (DVD)Replies: 7Last Post: 1st Aug 2007, 10:42 -
DVD burning problem
By Neil_2004 in forum DVD RippingReplies: 12Last Post: 30th Jun 2007, 18:14 -
DVD burning problem
By ea7770 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jun 2007, 15:17
