Hello, all.... and SOS!
I've had my panasonic dmr-e100h almost a year now, and I fear I just killed it. While in the dubbing screen, I accidentally inserted a DVD that was not blank. While it was in "READ", I went into speed selection, and then it froze, responsive to nothing. Finally I unplugged and plugged it in again, and when it is plugged in, the display just shows that spinning circle like it's trying to read the DVD... and that's all it does. The "DVD" light is on, but that's all. It responds to nothing. Tried unplugging and replugging again, and this time left it on for about 12 hours. Nothing doing, still just spinning.
What to do??
Thanks so much in advance
--- rita
Try this: press and hold the power button till the machine shuts off. Then with the machine off press and hold "stop" and "channel up" on the recorder for five seconds and release (release both buttons after 5 seconds whether something happens or not) The unit should turn on and eject the disk.
Ann, I don't know where you learned this voodoo magic, but you are a genius! Imagine my shock when it actually worked!
Thank you for saving my machine!
-rita
Rotating (spinning) a video for 360 degree
By affter333 in forum Newbie / General discussionsReplies: 3Last Post: 26th Jan 2012, 06:02 -
Spinning telly
By tilke in forum Capturing and VCRReplies: 2Last Post: 18th Oct 2011, 18:31 -
Case fan not spinning
By beavereater in forum ComputerReplies: 18Last Post: 15th Sep 2011, 15:51 -
Roxio Toast 8 - cannot burn an avi file. Just get spinning beach ball!
By Ivor Bigone in forum MacReplies: 10Last Post: 4th May 2008, 06:25 -
Control wheel joystick for spinning through video
By deanbrown3d in forum ComputerReplies: 4Last Post: 28th Sep 2007, 02:05
