  1. Hi,
    DVDx doesn't start encoding after pressing encode. Yesterday I encoded my first film with DVDx 1.6 and all worked fine. But now I want to encode the same film once more, because I didn't use a good bitrate.
    So, I canceled the old AVI-File from my HDD and choosed a better bitrate and wanted to start encoding again. But after
    pressing encode DVDx doesn't start. But there is no Error-Message. It simply doesn't start.
    All other adjustments are the same as before.
    I have the problem only at using the mpeg4 codec. I'm using DivX4.11. Encoding VCD or SVCD is no problem.
    Other films I can't encode, too! Only the first time encoding worked.
    I tried the same as described before with another Win-installation on another HDD but at the same Computer.
    The same problem appeared...
    Does someone know this problem?
    Xorxus
  2. uninstall the codec and reinstall it ...that should help
