Today I made a compliation of 9 AVI assets that indicated it would give a
4.14 GB burn then made a menu with audio. When I checked the resulting VIDEO_TS folder with My Computer it showed on 2.41 GB. When I burned with Nero It showed 2.416 GB. The burned DVD plays fine.
Any ideas?
svcd2dvdlog-20050311141732.txt
Yes. This is a known issue & is resolved now and will be sorted in RC6
Thanks, Chrissy Boy. When they print the computer dictionary they will
put your photo for the definition of Tech Support!! -
I think I am having the same problem. I have 2 divx assets (movies). When I put the first one in, the bar jumps way past the 4500mb line, and when I put the other in it does the same. I then hit the "Auto Fit" button and it puts it right at 4500mb line. But the resulting DVD is only 2.89gb. Not sure if I am losing more quality or not?
Is this the same issue that will be resolved in the next release??
Thanks. -
Yes it is.
estimated size of a video clip
By ansmit in forum Newbie / General discussionsReplies: 3Last Post: 20th May 2010, 16:13 -
Improper joining?
By LWC in forum EditingReplies: 6Last Post: 21st Mar 2009, 20:58 -
Sony Vegas rendering problem. Movies get much larger than estimated.
By Night-Blade in forum EditingReplies: 4Last Post: 2nd Jul 2008, 15:57 -
VirtualDub-MPEG Warning Improper Join?
By geewhiz in forum DVD RippingReplies: 2Last Post: 23rd Jun 2007, 08:10 -
Estimated Size Problem
By NHLroyrocks in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2007, 02:17
