Hi! i have a bunch of clips (mpg 2 of 2 hours) in my pc. im using the latest nero to burn it to dvd. my problem is it is saying that it is too big( over the 4gb ) to burn. does nero have an option to ask for another disk instead of me splitting all my clips to 2 1 hr files?
thanks
Nope, don't think it will burn onto two DVDs. In NeroVision Express you can easily fit 2 hours of video onto a DVD by selecting the More button down at the bottom, then Video Options, and playing with the transcoding quality settings.
Reauthor and use a lower bit rate
There is nothing illegal, until you get caught!
Making Blu-ray disks from multiple *.tivo files?
By aprest in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Apr 2010, 16:47 -
Burn large MKV file onto several DVD-R disks
By fazza8 in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Jan 2009, 07:28 -
SHW-160P6S can't write DVD-R disks using nero 6
By kwgpc in forum DVD & Blu-ray WritersReplies: 11Last Post: 8th Sep 2008, 11:02 -
What burner should i use to burn double layer disks
By Trident5 in forum DVD & Blu-ray WritersReplies: 8Last Post: 25th Sep 2007, 06:51 -
Unable to burn with multiple DVD recorders with Nero 7.9.6.0
By Burner127 in forum Authoring (DVD)Replies: 1Last Post: 7th Jun 2007, 00:47
