  1. Member Gargoyle's Avatar
    Jul 2001
    Southern New Jersey, USA
    I recently installed a Fusion HDTV card, and have been trying to convert the captured .TP stream to DVD with no luck.
    File info - 1280x720, 59.94 fps, 16:9 AR. (the actual video is 960x720, 4:3 AR with black bars added to the sides)
    My attempts:
    1. PVAstumento (convert to "corrected" MPEG2 and demux) > MPEG2Schnitt (cut commercials) > VirtualDub-MPEG2 (crop and resize,frameserve) > CCE basic (re-encode) > author w/ DVDAuthorGUI.
    RESULT: Audio gradually drifts (in sync at beginning, out of sync by the 40% point, and continues to get worse).
    2. PVAstumento (convert to "corrected" MPEG2) > VirtualDub-MPEG2 (cut commercials, save audio, crop and resize,frameserve) > CCE basic (re-encode) > author w/ DVDAuthorGUI.
    RESULT: Audio out of sync
    3. HDTV2MPEG2 (convert to MPEG2) > VirtualDub-MPEG2 (cut commercials, save audio, crop and resize,frameserve) > CCE basic (re-encode) > author w/ DVDAuthorGUI.
    4. HDTV2MPEG2 (convert to MPEG2) > VirtualDub-MPEG2 (save audio, crop and resize,frameserve) > CCE basic (re-encode) > author w/ DVDAuthorGUI.
    5. HDTV2MPEG2 (convert to MPEG2) > VirtualDub-MPEG2 (save audio, frameserve) > CCE basic (re-encode) > author w/ DVDAuthorGUI.
    6.Tried using the supplied "FusionConverter" on the original .TP file to convert to DVD-compliant MPEG2, and the audio is still out of sync.
    Has anyone had any success in converting the Fusion .TP files to DVD? Any tips or hints?
    You can't fool me, I'm a moron!
  2. Member DVWannaB's Avatar
    Dec 2001
    try the avsforum.com HDTV HTPC board/forum. Lots of info on HDTV cards and processing/handling *.ts streams. Good luck.
  3. Member Soopafresh's Avatar
    Jan 2004
    Run it through Mpeg2Repair first http://users.adelphia.net/~mwilczyn/mpeg2repair/
    Run the repaired file through HDTV2MPEG2
    Test the new .MPG file for good sync
    Encode to DVD compliant Mpeg2 WITH commercials (yes, it will take longer to encode)
    Check encoded 720x480 file for good sync
    Cut out commercials
    Check again for good sync
    Demux
    Author
  4. Member Gargoyle's Avatar
    Jul 2001
    soopafresh -thanks for the info, but I think I found the problem:
    (from the DVICO website)
    date - 2005-03-15 version - 2.99.07
    "[Changes since 3.0 Beta2 Release (2.99.05)]
    "- Fixed the out-of-sync problem on the long-term recording."
    I'm testing/converting a new capture now - we'll see what happens.
  5. Member Gargoyle's Avatar
    Jul 2001
    UPDATE - It looks like the driver update solved the problem; I did a 2 hour capture and converted it with no sync problems (Woo-hoo!).
