Hi,
I have a couple general questions about firmware. I bought my burner in Toronto and it has Firmware version 1.01 installed on it. I have found a type of media I like (Verbatim DVD+R 4X) that burns very nicely.
Should I mess with a good thing, or is it always a benefit to move to the current firmware? Other than installing the wrong firmware for my drive, are there any risks involved with moving up?
Lastly if I do decide to move up to 1.17, does it matter whether I pull the upgrade file from the Pioneer USA, Europe or Australia website? They all seem the same but have slightly different file names.
Thanks so much everyone.
TK
I would be surprised if the newer firmware would mess up the writing of an older Verbatim +R. Also, even though Pioneer US maintains that the firmwares from different Pioneer sites MIGHT be different, no one I have read here has found this to be true. Lastly, I have updated Pioneer drives many times without problems. As long as you select the correct drive and your power doesn't die you should be OK. With newer media and improved write strategies I have found it worth the risk; so much so that I just got a new RAM drive and I would not buy Panasonic because they refuse to update firmware.
Still a few bugs in the system... -
I flashed the 109 to firmware 1.40 after getting some really bad scans with fw 1.05 on crap media (optodisk) my bro gave me. The disks burned with fw1.05 gave quite good scans with fw1.40, and those burnt with fw1.40 gave even better scans. The biggest improvement was in the reading ability, now i can even read -R disks burned with NEC ND1300A.
Pioneer DVR-216 and Firmware
By dqtus in forum DVD & Blu-ray WritersReplies: 5Last Post: 27th Mar 2009, 02:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 07:20 -
How do I update the firmware on my Pioneer 109 DVR?
By Boogie7910 in forum DVD & Blu-ray WritersReplies: 2Last Post: 26th Nov 2007, 04:44 -
Pioneer DVR-106XA firmware needed
By Stevie69 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Jun 2007, 13:46 -
Changing the internal PIONEER DVD-RW DVR-109 Drive's Region Settings
By vidmarc in forum MacReplies: 5Last Post: 4th May 2007, 08:48
