  1. I have two SVCDs that I'm trying to put on one DVD. I was using this guide. When I try and convert the mpg file using VCDEasy then I get this error.
    Originally Posted by Error
    ".dat to .mpg conversion" execution failed:
    fread(): invalid arguement
    What could be causing this problem?
  2. That gave me
    Originally Posted by error
    Sector 143378 couldn't be read
    Error 05/21/00
    RETRY
    IGNORE this sector
    or QUIT
  3. Ignored it and got this
    Errors occured during reading
    Number of errors: 20918
    Last error address: 164295
    Last error: 05/21/00
    Delete this file?
    YES or NO
  4. OK, I got the first file to work and it imported into DVDLab. With the second file, when it tries to demux, it locks up at 80% and won't go any farther. Any ideas?
  5. OK, I got it to demux with TMPGEnc. Now, when I compile the DVD, the audio sounds scratchy in places. Anything I can do to fix the audio?
  6. look at besweet or all audio tools audio tools or leave it as is.
    The electronic components of the power part adopted a lot of Rubycons.
  7. I got it to work!!
    Instead of converting straight from mp2 to ac3.....I first used Goldwave to resample the audio directly from the mpg file, then saved it as a wav file, then converted the wav to ac3 using ffmpeg.
    Thanks for all of your help.
