Hi,
I used DVD Decrypter to rip the main movie and ISOs from a video DVD, everything ripped ok, except for the last 5% of the final VOB (I've used every trick to get the last bit but no joy). However when I looked at the last incomplete VOB file, I discovered it is half way through the end credits anyway so all I'm missing is a few credits that I don't care about.
BUT DVD Shrink will not recognize the data when I try to access it with 'reauthor' -- no 'title' appears. I don't even need to compress the DVD the total is 3.8 GB. Is there some way I can fix the problem so I can burn it with the incomplete final VOB file?
Thanks,
Matt
Results 1 to 13 of 13
Maybe you can burn with DVDDecripter. Rip with "ISO Read" to an .iso image, burn with "ISO Write" to disc.
is the DVD scratched or damaged at all?
have you tried changing the DVDDecrypter settings to be more aggressive?
do you not have another DVD drive you can try it in?
why not try using an older version of DVDShrink to grab the movie? The older versions were not as fussy so you may be able to reauthor and grab just the bit you want
failing any attempt to re-rip, have you considered demuxing your files and reauthoring them again? sometimes that can fix the problem. try Vobedit and Ifoedit for this.
you may need to 'recut' the end. i'd feed the demuxed files into cuttermaran and chop off the credits before the problematic bit of file occurs. then use this new set of files to rebuild your DVD.
i take it you dont care about the menus?never absorb anything bigger than your own head -
Many thanks. But...
I don't know what 'demuxing' means or how to do it. Can you explain please?
Otherwise I think I will try the vobedit and cutterman angle. Do I use cuttermaran first and then vobedit?
and yes I don't care about the menus.
Thanks. -
Many thanks.Originally Posted by MackemX
Yes, the DVD is scratched a bit, hence the problem.
Yes, I have tried setting DVD Decrypter to be more aggressive, retrying read's '50 times' and hardware retries '20 times' --these are the maxes. What happens if I set 'ignore all errors'? Will the resulting vob file be the correct size, etc. with just the few 'wrong data', in other words will DVD Decrypter do something smart and approximate the unread data? After all it's just the 2nd half of the end credits that'll have errors and I don't care about that. Is there another way to make DVD Decrypter more aggressive?
No I don't have another drive to test it on, except my standalone player where the film plays fine until the dodgy end credits.
I could try an older version of DVD Shrink, which version do you suggest?
Thanks. -
I think all you need a what's called a "mock strip" in IFOEdit, to readjust a few pointers in the VOB file. This takes about 1mn, so if I were you that's what I'd try first. Usually, when shrink complains about a DVD, a mock strip fixes that.
Here's the procedure. Make sure you keep a copy of the original VOB and IFO, just in case!
Open the IFO corresponding to the VOB in question in IFO edit, then click on VOB Extra.
Options
[ ] Strip Streams'
[ ] Strip VobID's
[X] Correct Vob-Unit (Navigation Pack) pointers in VOB-files
[X] Correct original IFO files
VOB EXPERT Options
[X] Remove P-Uops
[X] Remove Macrovision
[X] Adjust Vob-Unit pointers.
[X] Adjust Audio/Subp point.
Also, uncheck
[ ] Auto-copy Menu Files to destination
Click OK, and when it's done click "save". It will overwrite the IFO, say Yes.
jeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob. -
Excellent!!
Hi Jean, thanks for your help.Originally Posted by jeanl
Does FixVTS do the same thing for those incomplete VOB fixings ?,,.,..:.:: jesus2099 / shamo + top-moumoute films limited ::.:..,.,, -
Hi Jesus2099,
I'm afraid I'm not at liberty to discuss FixVTS any longer. Sorry about that.
JeanlMenuShrink a free tool to shrink menus into stills with or without audio!
Although this subject might be dead, I'll mention that the fix given by "jeanl" worked on an incomplete VOB\IFO
(incomplete with DVD Decrypter at 99%). The only difference was I was trying to use the incomplete VOB with AutoGK and after finishing the audio cut out half way thru. Thanks to "jeanl" audio and movie now end at the song credits......Thanks again
convert H.264 to use with Final Cut Express. Streamclip problem
By robinhall in forum MacReplies: 1Last Post: 28th Mar 2010, 15:41 -
Importing VOB files--iMovie, Final Cut Express? New to Mac
By Theresa in forum MacReplies: 14Last Post: 7th Apr 2009, 08:54 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Mac final cut problem
By James in HD in forum MacReplies: 5Last Post: 15th Nov 2007, 20:00 -
Pulling video from VOB formated CD for Final Cut Express HD
By nhdaveq in forum Authoring (DVD)Replies: 1Last Post: 2nd Aug 2007, 00:30
